chris69 307 de Diamant
cybernck 307 Addicted
Posté le: Lun 29 Aoû 11 à 22:05 Sujet du message: |
Time to move on to happier updates, I think! Haha.
It's time to revisit and finally complete the audio system, starting with a messy job of properly
installing the front speakers at long last! Typical French - holes everywhere in the door, except
where I need one to be.
Inner skin was cut-out and prepared to take a custom MDF speaker pod. With the pod in place
and firmly attached to the door's inner skin, we treated outer skins, pods and door cards treated
with a couple of coats of bitumen, for at least some vibration damping.
And finally, speaker installed and all the holes sealed. What an unbelievable improvement of
my audio system, quite possibly the biggest single upgrade I've done so far!
Door cards back on, though I did have to remove the lower hole cover I had made, so I will
have to revisit it later and also add LOADS of Dynamat or such material everywhere in the doors.
The next update will be all about audio as well .
Photos here: http://photos.cybernck.com/307breaknck?page=10
Posté le: Sam 10 Sep 11 à 01:11 Sujet du message: |
Time to finally complete my envisaged audio system!
Out with the old 4-channel amplifier (Magnat Rave 440, on the left, good little amp), in with
the new one (Focal FP 4.75, on the right). Specs: 4 x 75W @ 4 ohms, 4 x 100W @ 2 ohms,
2 x 200W @ 4 ohms. Full active crossover and an output for a second amp.
Previous configuration was 2+1 ch, but since I'm going to run front Focal 165K2P speakers
on Focal FP 4.75 in bridged mode with low gain, it's accompanied by it's monoblock brother,
Focal FP 1.800 (with remote gain control) for the subwoofer.
Specs: 1 x 400W @ 4 ohms, 1 x 600W @ 2 ohms, 1 x 800W @ 1 ohm. Focal 33KX beast
will be unleashed :-).
Additional wiring was required for the additional amp.
With the front speakers properly installed and with the addition of new amplifiers, I am very
happy with my audio system now! I keep hearing details I previously haven't, in the same
tracks and songs. Next mods will be sound deadening and a better headunit.
As you can see, the 18" RS GT wheels are back on the car as well .
Posté le: Mar 04 Oct 11 à 23:27 Sujet du message: |
With the audio install finished at long last, it was time to turn my attention to exterior and
fit parts I've had laying around for quite some time, but the first job was to get the bodywork
cleaner and shinier by a professional polisher.
Then came a long awaited solution to a "radio controlled car" antenna, in form of a short
OE antenna, part number 6561.QQ, found on various models (607, 807 etc). Fits nicely
and radio reception seems fine, but I don't listen to radio at all, so it doesn't matter to
me either way .
Someone had stolen my rear wiper blade a long time ago and the wiper arm (6429.T
had a lot of play in it, so I bought both parts new. The wiper arm required a bit of persuasion
from an angle grinder to come off though.
As I decided to update the tails lamps to Phase 2, I went for Phase 2 side indicators as well.
6325.G3 - 206 Phase 2 side indicators (x2). Exactly the same as 307 items (6325.G4) but at
half a price. Go figure. Not too visible in daytime, as the bulb is hidden.
Phase 2 tail lamps! Compared to Phase 1 lights, they look much brighter, fresher and more red,
thought with a bit of a "China" look and feel to them. They fit the car straight on, but you need
additional two 5W bulbs, compared to Phase 1 lights.
Exterior mods completed. Not much of a photo, but shows how shiny the car is.
That's it for the bodywork mods, for the time being anyway.
Photos here: http://photos.cybernck.com/307breaknck?page=11
Posté le: Mar 09 Oct 12 à 23:09 Sujet du message: |
With my cycle racing season finally over, I'm going ahead with my little project, finally mounting
some parts I've had laying around for nearly a couple of years now. Here you can see 307 Automatic
alloy pedal set I got off eBay, a genuine 307 CC leather steering wheel form a UK breaker's yard
and finally, some genuine 307 alloy front sill plates, part number 9623.76, also an eBay special.
Mounting the brake pedal using supplied allen screws is straightforward after removal of the original
rubber pedal cover, as the holes for the screws are already there. However, throttle pedal was a bit
of a challenge and had to be removed because of the construction of the pedal.
It would have been nearly impossible to position it right while at the same time manage to bolt it up,
so we riveted it on instead. The removable leg rest offers easy mounting of the leg rest pedal.
We opted for riveting on this one as well.
Next up, the steering wheel. After disconnecting the battery, airbag is easily removed using two
flat-headed screwdrivers inserted in the holes at the back of the steering wheel. A word of warning -
do not fully unscrew and remove the main torx bolt until you've managed to release the steering wheel
from the steering crown, as you'll probably end up tearing off all the airbag connectors!
Fitting the other wheel is a reverse of the removal. And there are no spare bolts left, for a change! :-)
And finally, fitting the sill plates is super-easy and quick, as it comes with a self-adhesive tape
on the back. You just need to lift the plastic cover and rubber seal off of the sill seam, clean up
and degrease the surface, test-fit the sill plate and and then stick it on. Job done!
I will continue with this "307 CC interior upgrade pack" in the next update too .
Full size photos available here: http://photos.cybernck.com/307breaknck?page=12
307 fever 307 de Diamant
Posté le: Jeu 25 Oct 12 à 22:17 Sujet du message: |
Next up - 307 CC white clocks with chrome rings, red needles and radial writing. Got them from the UK
(eBay once again), so they're in mph but they also have a km/h scale, in small print.
It was not a simple plug'n'play affair though, because I needed to keep my circuit board. Therefore,
armed with a Torx bit, I started disassembling them to bits. I even had to go the lengths of cutting out
and swapping the center "display" part, so the warning lights would remain correct.
Et voila! Clocks finished, fitted back into the car and looking classy, in my opinion.
And finally - a "before and after" shot, to sum it all up. The new details really smarten up the interior
and the steering wheel is much nicer to use.
As far as interior mods are concerned, that's it for now, but I've definitely got another thing or two planned ;-).
Mecano.S 307 de Diamant
Posté le: Ven 26 Oct 12 à 09:19 Sujet du message: |
welcome! superbe ce SW
307sw-hdi110 Banni !
Posté le: Ven 26 Oct 12 à 10:17 Sujet du message: |
they are your top change that you did! she is super beautiful your 307 now! sorry for my english I go on a translator
jej307 307 de Diamant
Inscrit le: 07 Oct 2008 Messages : 2729 Localisation : Loire
Posté le: Ven 26 Oct 12 à 11:20 Sujet du message: |
Very beautiful this SW i like your wheels
_________________ 307 Sw Hdi 136 2005 quiksilver, phare maison, feux phase 2, jantes Exona 18", Aileron, bas de hayon et calandre ABBES photos P.71
Posté le: Ven 26 Oct 12 à 14:52 Sujet du message: |
What will be the next change??
Posté le: Ven 26 Oct 12 à 17:07 Sujet du message: |
Wait and see what means?
bobyrush 307 de Diamant
nico061 307 de Diamant
Inscrit le: 28 Mai 2012 Messages : 6236 Localisation : Orne (61)
Posté le: Ven 02 Nov 12 à 12:53 Sujet du message: |
nico reve pas ta 307 ne montera pas a 240 km/h a moins tu que modifi le moteur !
Posté le: Ven 02 Nov 12 à 12:56 Sujet du message: |
yes ! but what he is going to put a counter up to 240 while the car can not go that fast?
Posté le: Ven 02 Nov 12 à 13:06 Sujet du message: |
sur ma 307 je peux mettre le limiteur de vitesse a 240km/h
Posté le: Lun 05 Nov 12 à 20:04 Sujet du message: |
quelqu'un saurait me dire ce que c'est le petit moteur avec le cable ?
Posté le: Lun 05 Nov 12 à 21:07 Sujet du message: |
Sur la 2eme rangee de photos ? C est le mecanisme de roue de secours sur SW
