Posté le: Dim 12 Juil 15 à 12:01 Sujet du message: MOTEUR QUI SE COUPE ET QUI NE DEMARRE PLUS.
BONJOUR A TOUS, JE VOUS EXPLIQUE LE PROBLEME QUE J'AI AVEC MA VOITURE DEPUIS UN PETIT MOMENT.
IL Y A 1 SEMAINE JE PREND MA 307 POUR ALLER QUELQUE PART A 10 KM DE CHEZ MOI, POUR Y ALLER AUCUN PROBLEME JE FAIS CE QUE J'AI A FAIRE PUIS AU RETOUR J'ARRIVE A MON PORTAIL ET TOUT D'UN COUP MON MOTEUR SE COUP ( JE PRECISE QUE JE N'AI PAS CALLER CAR IL N'Y A PAS EU D'ACCOUPS ) DONC JE REDEMARRE ET JE ME GARE CORRECTEMENT.
3-4 HEURES PLUS TARD JE REPRENDS MON VEHICULE JE DEMARRE NORMALEMENT PUIS LE TEMPS D'INSTALLER MON FILS A L'ARRIERE,MON MOTEUR SE COUPE ENCORE UNE FOIS MAIS PAR CONTRE LA IMPOSSIBLE DE LE RALLUMER........ ON ME DIS DE POMPER LA POME A GASOIL DONC JE LE FAIS ET PAR MIRACLE SA REDEMARRE. PENDANT 5 JOURS AUCUNS SOUCIE JUSQU'A HIER MON MOTEUR SE COUPE ENCORE DEVANT UN ROND POINT..... JE REDEMARRE AVEC INSISTANCE MAIS ELLE REDEMARRE TOUT DE MEME. JE GARE MON VEHICULE PUIS LE LENDEMAIN ( AUJOURD'HUIT ) JE DEMARRE MA VOITURE, J'AVANCE A 5 METRE ET ELLE SE COUPE ENCORE UNE FOIS ET PLUS MOYEN DE LA RALLUMER JUSQU'A CE QUE JE REPOMPE LA POME A GASOIL UNE FOIS DE PLUS.......
Posté le: Dim 12 Juil 15 à 12:06 Sujet du message: A VU D'OEIL.
DE PLUS EN OUVRANT MON CAPOT JE M'APERCOIT QU'IL Y A DE L'HUILE AU NIVEAU DU 2EMES INJECTEUR. ( J'AI CHANGER LES JOINTS DES 4 INJECTEURS IL Y A 2 ANS. IL N'Y A PAS EU DE PROBLEME DEPUIS CE TEMPS.
