Peugeot 307 - Voir le sujet - P307SW airbag fault - Forum Peugeot 307 - 307CC - 307SW
P307SW airbag fault
Brx
MessagePosté le: Mar 08 Nov 16 à 14:19    Sujet du message: P307SW airbag fault Répondre en citant
Hello!
First of all, greetings to all on the Forum! I'm from Croatia, and I own P307SW 1,6HDi, 110HP (2008).
I have problem with the airbag...2 years ago, I've received "Airbag fault" error, and when connected to the diagnostic, the error was: fault on RH lateral and RH curtain airbag igniters: resistance to high. That's probably problem with bad connection or bad igniter, because I have soldered wires under the seat. I solved that problem by completely disabling the right airbag side curtain with DiagBox (put it on "absent") and everything was OK untill now, when outside temperatures went down to 0°C (morning temp). Now I have intermittent airbag fault:
9691 (Fault on the RH lateral and RH curtain airbag igniters in series):
Characterisation of the fault: Present but not configured.
It's not always on, it goes on and off all the time, and it's pretty annoying.
Does anyone has any idea what could it be and how to solve it?
Thanks and regards,
Brx
