glcgsm Curieux
Inscrit le: 31 Jan 2008 Messages : 14 Localisation : Right There
gribouille 307 de Bronze
Inscrit le: 20 Aoû 2007 Messages : 287 Localisation : 68 - Buhl
Posté le: Jeu 08 Mai 08 à 22:13 Sujet du message: |
Hi! the problem "level oil fault" is normal. your problem is with water? you can't go at Peugeot for understand this problem?
good luck!
_________________ 307 XT HDi 110 + régulateur + prise 12v suppl. + chargeur CD + déciglage + alarme + jantes Equinoxe => à venir : pack look
L'urgent est fait, l'impossible est en cours; pour les miracles prévoir un délai
http://307-city.miniville.fr/
Br3tz 307 Hors Catégorie
Posté le: Ven 09 Mai 08 à 18:54 Sujet du message: Re: PPS2000 tutorial & error interpretation |
| glcgsm a écrit : | Hello everybody,
Sorry for writing in english, but my french is not so good. Please, feel free to reply in french if you want, I'll do my best to understand the message.
I wonder if there is any "Guru" of PPS2000 on this forum. I have read an error on my car with PPS2000 and I cannot understand it:
"Remote permanent fault. Fluid temperature data. Incorrect value received"
I understand that there is a problem with a probe which might be defective or even missing, but I dont know what "fluid" means. It is transmission fluid ? Power steering fluid or ...what ? The gearbox is manual, so I dont think a temperature sensor it is fitted on it... For sure it is not related with the coolant temperature, this one gives another error.
Please, help me out...
Best Regards,
glcgsm.  |
hi, your default comes from the oil sensor, and it s impossible to remove the default with the pps but if you ve the lexia 3 you can correct and remove this default
Best regards
_________________ 2.0 L HDI 110 Navetec ,RT3 Couleur , becquet, feux avant bluevision, feux arriere T6, seuils de porte alu., régulateur de vitesse, rétro rabattables...
