Peugeot 307 - Voir le sujet - PPS2000 tutorial & error interpretation - Forum Peugeot 307 - 307CC - 307SW
glcgsm
MessagePosté le: Mer 30 Avr 08 à 20:52    Sujet du message: PPS2000 tutorial & error interpretation Répondre en citant
Hello everybody,
Sorry for writing in english, but my french is not so good. Please, feel free to reply in french if you want, I'll do my best to understand the message.
I wonder if there is any "Guru" of PPS2000 on this forum. I have read an error on my car with PPS2000 and I cannot understand it:
"Remote permanent fault. Fluid temperature data. Incorrect value received"
I understand that there is a problem with a probe which might be defective or even missing, but I dont know what "fluid" means. It is transmission fluid ? Power steering fluid or ...what ? The gearbox is manual, so I dont think a temperature sensor it is fitted on it... For sure it is not related with the coolant temperature, this one gives another error.
Please, help me out...
Best Regards,
glcgsm. Rolling Eyes
gribouille
MessagePosté le: Jeu 08 Mai 08 à 22:13    Sujet du message: Répondre en citant
Hi! the problem "level oil fault" is normal. your problem is with water? you can't go at Peugeot for understand this problem?
good luck!
307 XT HDi 110 + régulateur + prise 12v suppl. + chargeur CD + déciglage + alarme + jantes Equinoxe => à venir : pack look
L'urgent est fait, l'impossible est en cours; pour les miracles prévoir un délai
http://307-city.miniville.fr/
Br3tz
MessagePosté le: Ven 09 Mai 08 à 18:54    Sujet du message: Re: PPS2000 tutorial & error interpretation Répondre en citant
glcgsm a écrit :
Hello everybody,
Best Regards,
hi, your default comes from the oil sensor, and it s impossible to remove the default with the pps but if you ve the lexia 3 you can correct and remove this default Exclamation
Best regards
